If the print is wide enough to have infill then it doesn't really matter how many walls you have as all the walls will fit (apart from in tight corners, perhaps.) So then the considerations are different. A very small number of walls can make the infill more visible as it can distort a thin wall.
1
burtoogle 516
Hello @Link, the situation hasn't changed, it's always best if the wall width is an even multiple of the line width. So a 1.2mm wide wall would print best with either a 0.6mm or 0.3mm line width. If the line width is 0.4 (or maybe just below) and the wall overlap compensation is enabled then you will get 3 full width wall lines and one that has been narrowed by the overlap compensation. Recent cura releases have a min flow setting which replaces extrusions with very low flows with travel moves and it is aimed at exactly this situation where a wall line has been overlap compensated down to almost nothing.
Link 35
Many thanks, very helping as usual !.
for a print which has infil, i.e no think walls and the interior is filled with infil, is there any advantage to having a even or odd number or walls set in Cura ?. Or does this make no difference. Thanks
