Smithy, thanks for the reply.
The printer I am using is a Creality CR-10S. There does not seem to be anything unusual about the filament. As I watch the feeder operate the filament is moving when the feeder gear turns, either way; there is only just a very small amount of movement and seems to be random.
Smithy 1,141
I don't know which printer you are using, but with the UM3 there is a bug with this plugin as far as I know. I don't have it in my mind exactly, but I read some days ago a post about such problems with the UM3.
Another possibility could be, that your feeder has grinded the filament and cannot move if forward. But this is something you would see on the filament and when you start the print the problem would still exists.
