22 minutes ago, Smithy said:Your nozzle is oozing during the travel to the other object, resulting in those strings.
There are several settings to avoid this, retraction, print temperature too high, .....
But when I look on your brim, it also looks not very good. Can you share some more infos, which settings, which material,....
I'm very new at this ?
for this case I used the software Cura 3.4.1, with a configuration recommended by the software.
- Layer Height 1.5
- Infill 15%
- without supports
- Print Temperature 210°
the material is PLA / PHA from Colorfabb
Smithy 1,088
