Tried 3.5.0 beta, a q from a noob
boelle
Posted · Tried 3.5.0 beta, a q from a noob
tried 3.5.0 and i must say its an upgrade coming from SLic3r PE
at least supports work far better
the only thing that i cant figure is how to make the start gcode work right
this is how i had it in slic3r:
G28 Z; Home Z
G28 Y; Home Y
G28 X; Home X
G29
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
G92 E0 ; zero the extruded length
G1 X50 Y0 F3000 ; go to the middle of the front
G1 Z0.1 ; close to the bed
M104 S[first_layer_temperature] ; set extruder temp
M109 S[first_layer_temperature] ; wait for extruder temp
G1 X100 E10 F200 ; make a thick line to prime extruder
G1 Z0.3 ; lift Z
G4 S2 ;wait 2 sec to bleed off excess pressure
cura starts to heat the bed before the G28's (and yes i could just use a single G28
but i want it to heat the bed after the G29
how would the above start code look in cura?
    i installed the printer as an prusa MK2 (one of the options when starting cura the first time)
    only changes i did was start gcode and end code
    and then the generic ABSsettings i made a copy off as the temps was ot what i wanted, and the default generic ABS also had the part cooling fan enabled.
    changed my start code to:
    G28 Z; Home Z
    G28 Y; Home Y
    G28 X; Home X
    G29
    M140 S{material_bed_temperature_layer_0} ; set bed temp
    M190 S{material_bed_temperature_layer_0} ; wait for bed temp
    M104 S{material_print_temperature_layer_0} ; set extruder temp
    M109 S{material_print_temperature_layer_0} ; wait for extruder temp
    G1 Z0.3 ; lift Z
    only get this extra line inserted automatic before that: M82 ;absolute extrusion mode
    my end code is:
    M104 S0 ; turn off extruder
    M140 S0 ; turn off heatbed
    G28 X; Home X
    G28 Z; Home Z
    G0 Y0 F5000 ; Move Y to middle of bed cooling fan
    M42 P11 S255 ; Turn on Bed cooling fan on
    M106 ; cool off nozzle
    G4 S660 ;wait 11 minutes
    M42 P11 S0 ;Turn off bed cooling fan
    M107 ; carriage fan off
    G28 Y; home Y
    M84 ; disable motors
    i also here get an extra line inserted before that: M140 S0
    i have read arround that sometimes start and stop gcode are taken from the json files and in my case that would almost be prusa_i3_mk2.def.json
    "machine_start_gcode": {
                "default_value": "G21 ; set units to millimeters\nG90 ; use absolute positioning\nM82 ; absolute extrusion mode\nM104 S{material_print_temperature_layer_0} ; set extruder temp\nM140 S{material_bed_temperature_layer_0} ; set bed temp\nM190 S{material_bed_temperature_layer_0} ; wait for bed temp\nM109 S{material_print_temperature_layer_0} ; wait for extruder temp\nG28 W ; home all without mesh bed level\nG80 ; mesh bed leveling\nG92 E0.0 ; reset extruder distance position\nG1 Y-3.0 F1000.0 ; go outside print area\nG1 X60.0 E9.0 F1000.0 ; intro line\nG1 X100.0 E21.5 F1000.0 ; intro line\nG92 E0.0 ; reset extruder distance position"
    i could either remove all the code or just remove the M82 part
    but the end code i cant figure
     "machine_end_gcode": {
                "default_value": "M104 S0 ; turn off extruder\nM140 S0 ; turn off heatbed\nM107 ; turn off fan\nG1 X0 Y210; home X axis and push Y forward\nM84 ; disable motors"
    there is only one M140 in there but i get 2, one without any comments one, where does that come from?
    hmm strange, even with those to set to " " i get this in my start of saved gcode
    G28 Z; Home Z
    G28 Y; Home Y
    G28 X; Home X
    G29
    M140 S100.0 ; set bed temp
    M190 S100.0 ; wait for bed temp
    M104 S210 ; set extruder temp
    M109 S210 ; wait for extruder temp
    G1 Z0.3 ; lift Z
    G92 E0
    G1 F3600 E-4.5
    where does the M82 come from? its not in my start code and its removed from the json
    i assume the G1 F3600 E-4.5 is inserted automatic based on my retract as not to ozze just before print start
    the end of the code looks like this:
    G1 F3600 E2091.48677
    M140 S0
    G28 X; Home X
    G28 Z; Home Z
    G28 Y; home Y
    M104 S0
    ;End of Gcode
    the M140 S0 and M104 S0 and the M82 also makes me scratch my head, they are not in the json and not in the end code for the printer
    i will give it a check in cura, been a long time since i used it last
    its more that i like to be in control of the start and end gcode so i know kind of can depend on how its created
    or at least i can know where thing come from
    i might have looked the wrong place but i could not find any settings that would leave heaters on
    i wonder if @SandervG can point me where the slicers gets those M82 and M140/M104 from
    the M104/140 with a comment after it are correct as those are in the end Gcode
        • 21 replies
