Thanks gr5.
The last photo is without glass, sorry me for the photo not very good.
The glass seems good.
I have problem to hit the right z measure and i dont know why but I see if I change the distance between glass and alluminium the z change.
I'm more worried about the difference between the back and the front.
whenever I do the manual leveling I need to try a lot of time for hit the correct measure of rear plate. If I do about 14mm in all 3 points I cant complete manual leveling because in to front the bed is crushed to the nozzle.
Really thanks for your support.
Edited by Gio26
gr5 2,210
In the last photo that looks like too much warping of your glass. This will be a problem if you try to print in either of the 2 rear corners but not a problem for small parts.
Please remove the glass and test the glass by itself (the aluminum plate can pull the glass into this shape so see if it's the glass or the aluminum that has most of the warp).
If the glass has this much warp then tell your reseller you want another one or you'll return the whole printer. Meanwhile keep using this glass until you get the replacement.
