On 9/28/2018 at 9:59 PM, gr5 said:The filament is coming out of the nozzle just fine. You don't need to do cold pulls.
What I see in the video is exactly what you expect when the leveling is too high. Just run the leveling again. Or don't even do that - just turn the 3 screws CCW as seen from below about a half turn to raise the bed up a bit. You can play with these as it's printing. Or you can push up on the bed to see that I'm right for a few seconds. I demonstrate this at about 3:14 in this video:
I tried moving the build plate closer to the hot end and it helped a little. However, the filament feeder is just gnarling up the filament rather than feeding it through.
I've already increased the temperature to 230C. Does it need to be even hotter? Did running out filament maybe destroy the hot end somehow, causing it not to heat as well as before?
What should I do?
gr5 2,243
cloakfiend 996
If someone did to my um2 what you did to your um2 at 4.35s into your video, id kick them out of my house! Thats printer abuse right there!
Great video though!
