Supports messing up Model
avillegas2
Posted · Supports messing up Model
For some reason, when I print supports on any models, the layer that is in contact with the supports does not print well. In other words, it is not smooth and the print is of very bad quality, and sometimes the supports are hard to remove. It seems as if either the supports fuses into the model, or the layer does not cools properly. It only happens when I print supports, otherwise, when there are no supports touching the model, it prints just fine. Any help on what I'm doing wrong? I am using a Creality 10s with Cura 3.5
My settings are set as:
Layer Height - .06mm (Extra fine)
Top/Bottom Thickness - .6mm
Wall thickness - .8mm
Printing temperature - 200 degrees
Plate temp. - 60 degrees
Retraction enabled
Retraction distance - 5mm
Retraction speed - 40 mm/s
Support pattern - ZigZag
Support density - 10-15%
Support Z distance - .265mm
Support X/Y distance - .7mm
