First / solid layers are dimensional smaller than infill layers
rhoogenboom
Posted (edited) · First / solid layers are dimensional smaller than infill layers
I'm looking for some pointers as what to check/adjust to get this issue resolved on my prints.
These prints are done in PLA, but aren't material specific. Cura versions: this happens with 3.5.0 and the previous 3.4.1. I don't think it's Cura version specific, I've had this issue for a while.
This is printed at the default 'fine' setting of 0.1mm and a modified fine setting where initial layer height was decreased and print speed reduced to 35mm/s
When I print, the bottom/100% infill layers seem to be dimensionally smaller than the layers higher up which are printed with infill. I even aborted a print, as you can see in the pictures where it shows the dimensional wideness changes at the infill printed layers.
Any thoughts or ideas of things I could change to fix this issue?
Picture 1 through 4 some examples where the first layers are smaller than the subsequent ones.
Picture 5 through 7 you can see it starts when printing infills.
Upload of pictures will be after posting as I need to do that from my phone.
Cheers,
Richard
Edited by rhoogenboom
