@rebekah_harper you mention 'developer access', so you are using an UM3 or S5 machine. Then yellowshark's suggestion for using a program with USB connection won't work.
What machine type do you have?
Which Bond Tech extruder model are you using?
For the UM3/S5:
- Enable developer mode
- Make an SSH connection and login with user name 'ultimaker' and password 'ultimaker'
- 'sendgcode T0' (or T1) this will select the left or right nozzle
- 'sendgcode M302 S0' disables the cold extrusion prevention, so you can move filament even when cold.
- 'sendgcode G0 E10' will move the filament 10mm.
yellowshark 152
Hi this may not be the best answer for you, I do not know what bond tech is, but this is how I do it. Load Repetier Host software (free), onto a laptop. Attach your laptop to your printer by USB. You will need to do a bit of printer setup in Repetier but is should not be difficult and most of the settings will be in your printer definition in you slicer. Load the STL file, on your laptop, into Repetier and use the Repetier GUI to move the material a measured amount.
Once fixed think about using the wonderful Repetier to control your printer on an ongoing basis
