Ultimaker 2+ Extended 0.8mm Nozzle Settings
cjh83
Posted · Ultimaker 2+ Extended 0.8mm Nozzle Settings
Hello Community,
I'm wondering if anyone else has found the Cura "recommended settings" for the 0.8mm nozzle to be 100% garbage for the Ultimaker 2+ for PLA.
The speeds seem way to fast when printing the walls (see images). But seem spot on for the base layer fill. I'm getting cornrows on the walls (again look at the walls on the images).
Has anyone done some trial and error and can give me the settings for PLA with a 0.8mm nozzle that seem to work? I'm about to spend hours tinkering with speeds, wall thickness, temps, etc. Before I do so I'm hoping I can build off someone else's work!
        • 56 replies
        • 29 replies
