Maybe a bit simple minded here.. but do you have the Combing mode on in Cura? its under the travel section.
On 10/26/2018 at 1:26 PM, geert_2 said:If you mean the single diagonal lines, these are not scars but sort of "travel lines" (I don't know the official name), where the nozzle travels from one point to another without stopping extrusion. I guess the idea behind this is that this causes the least amount of pressure- and flow change in the nozzle, and thus the most stable temperature and extrusion? But I don't know if there is a setting where you could turn this on or off. I just consider it part of this specific production method. Like seam lines and ejection marks are part of the injection moulding process.
I switch from direct extrude to Bowden setup and then the travel line show up. I also cut the teflon tube to minimize the distance from motor to hot end but same result. Sometimes i hear click on extruder motor. My step/mm are at 100. And the calibration show that i am extruding the exactly 100mm.
On 10/26/2018 at 1:53 PM, IwanBeentjes said:Maybe a bit simple minded here.. but do you have the Combing mode on in Cura? its under the travel section.
Combine mode set to ALL and Z hop when retracting is disabled.
6 hours ago, yellowshark said:
With direct extrude i did not suffer from travel line, but when i switch to bowden extrude then the travel line shows up.
I set the retraction value to 9 because when i do those retraction test which can be found on Thinginverse none of other numbers make a difference.
Sorry silly me I thought you were referring to the retraction minimal travel; who knows why when you said retraction distance!!
20 hours ago, 3dDiyC said:Combine mode set to ALL and Z hop when retracting is disabled.
Maybe try combing mode "not in skin" For Z hop i have no idea if it will help with your problem but you can try turning it on.
geert_2 553
