Travel Moves During Spiralize Outer Contour Printing
KevinZ
Posted · Travel Moves During Spiralize Outer Contour Printing
Hello!
I am running into a weird issue where there are many travel moves during a vase mode / "spiralize outer contour" print.  The resulting print ends up containing lots of blobs from the starts / stops of the travel moves.  printer works fine with other geometry when using the same profile, but for some reason it now makes z-hops between layers.  Any tips or help would be greatly appreciated.
CFFFP_601-Pendant.3mf
    I changed the surface mode to normal and it looks a lot better in the layer view. BTW, spiralize is intended to be used with solid models rather than just shells.
        • 28 replies
