Filament stuck in feeding tube after running out during print
Posted
· Filament stuck in feeding tube after running out during print
This is normal but can be fixed easily.
Remove the clamp from the socket where the Bowden tube goes into the feeder. Then push the socket down with your finger and you can pull out the tube from the feeder. Now you have access to the tube, remove the filament and then put the tube back into the feeder. Push again the socket, push the tube down and install the clamp again.
Smithy 1,145
