@gr5 Thank you for your quick reply. Of course, your first mentioned steps with regards to repair and ejecting the SD card, I paid extra attention to the first time the problem occurred.
I am going to take two fresh SD cards, view every uploaded .gcode with a gcode viewer. I will keep posting positive or negative results.
gr5 1,968
This is bizarre. It sounds like a corrupt SD card. Make sure you do a "eject" before removing the SD card to be sure the file system isn't corrupt. You might want to "repair" the SD card. For example windows will usually prompt you to repair the SD card when you stick it in a windows computer.
If that's not the problem you should definitely open the gcode file in a gcode viewer before you print the object. One simple one is at the website: http://gcode.ws
Just drag and drop your gcode file FROM THE SD CARD! Not from the hard drive. Onto the box in gcode.ws.
