Posted · Some questions about the S5
Can you somehow send G Code commands directly to the S5? Not while printing. What G code is for auto leveling? Can it be skipped if you alter the print file?
What is the difference between a AA core and a BB core, they look the same.
Has any designed a holder for extra cores?
    Posted (edited) · Some questions about the S5
    I can’t speak to the g-code question however; the AA and BB cores externally appear the same with the differences within. The BB Core being uniquely designed for PVA.
    With regards to a Print Core holder; I personally have not found a need for one but suspect that there is one out there and if not, it would be a relatively easy item to design.
    Takes care.
    Edited by Shadowman
    Spelling
    I will try to answer some of your questions:
    Yes this is possible via SSH connection (you have to turn on the developer mode first) and then login and send gcodes with a command line tool. I haven't used it myself yet, so I just know it is possible, for details you have search the forum here, there are some other posts where you can find the excact name of the command line tool.
    I am not sure if you can trigger auto leveling manually, because as far as I know the printer handles the leveling and not a gcode command. But maybe there is also a gcode for it, I don't know.
    Only from outside. The BB core has a different inner shape which is needed for PVA that the material will not clog the nozzle. I have seen somewhere a cross section picture, but could not find it yet.
    There are a lot of print core holders on Youmagine and Thinigverse. But not all of them are really working. I printed some, but they all have a very tight fit and I decided to not press fit my print core into the holder 🙂 But check the simpler ones, they fit better.
    • 5 years later...
    Hi Smithy,
    "Yes this is possible via SSH connection (you have to turn on the developer mode first) and then login and send gcodes with a command line tool. I haven't used it myself yet, so I just know it is possible, for details you have search the forum here, there are some other posts where you can find the excact name of the command line tool"
    Can you please suggest me how to do that. Thank you
    9 minutes ago, Abdur said:
    Quick update ... I can access to my printer using ssh which looks like this
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
       __  ______  _                 __                 _   _
      / / / / / /_(_)___ ___  ____ _/ /_____  _____   _| |_| |_
     / / / / / __/ / __ '__ \/ __ '/ //_/ _ \/ ___/ _|         |_
    / /_/ / / /_/ / / / / / / /_/ / ,< /  __/ /    |#| (^) (^) |#|
    \____/_/\__/_/_/ /_/ /_/\__,_/_/|_|\___/_/       | ======= |
    Welcome to our kingdom. Please be responsible.
    UltimakerSPro: firmwareversion
    Ultimaker S5: model   can anyone suggest me some commands to send gcode or control the printer using shh commands. Thanks
    Smithy has not posted in a long time.  @Dustin may be able to help.
    UltiMaker wont formally provide support for this..they are on their own.
    Hi Dustin,
    I am looking for some suggestions  regarding controlling printer/modifying gcode using ssh can you help me in this regrad..Thanks
    8 minutes ago, Abdur said:
    Hi Dustin,
    UltiMaker wont formally provide support for this..you are on your own.
