18 hours ago, ahoeben said:I'm the creator of the Z Offset plugin. I'll admit I have never tested the plugin with an S5 (or an UM3 for that matter). Could you try saving the gcode to a file, and inspect the first move on the first layer?
The code generated is attached. First move is 0,37 (0,27 first layer height + 0,1 z offset). so it's correct.
But there is a G92 just after resetting the origin to 0.27.
I believe this one is not properly interpreted by the firmware.
ahoeben 1,968
