obviously @Smithy's solution is the safest, but I see no reason why you can't just set the toolchange manually in the Gcode file. If you want to look at the way the UM3 handles the gcode just slice a tiny dual print (stack two smal cubes) and look at the gcode around the layer where the change occurs (use f.e. Notepad++ to change the gcode files). Look at codes like T0, T1 (set active nozzle) and M104, M109 (set temperature)
edit: save to / print from USB if you manually alter the Gcode
And read here for more on the UM3 Gcode;
Edited by ultiarjan
added remark
Smithy 752
Normally you have to design your object in two parts. Then you import every part into Cura and select which extruder should print the selected part. Then you merge both objects together and they automatically move to the original position they had in your CAD software, to get again one combined object in Cura, but with different settings (extruder).
mcdavidr 0
I have been trying to do a plane split in Meshmixer but am not having much luck.
