Hi yes, i am using the USB that came with the printer.
It read the firmware update from it no problem
Load the print file, the printer goes through the bed leveling process and then the head just sits in the corner and says Ready to Print
but does nothing. Looking like it cannot load the full print file.
I have tried different files etc still and still does not print
Good use of $8,000!
Smithy 1,135
Is the stick detected by the printer or nothing?
Have you tried the one which comes with the printer?
The most common failure is, that the filesystem of the stick is not compatible with the printer. Try to format the stick, with FAT or FAT32 and try it again. The one which comes with the printer is already formatted correctly.
