Hi @DrSchmoll, if I'm not mistaken we're in the process of removing some older legacy versions to keep things organized and structured. Unfortunately the removal of some versions seem to have gone a little bit faster than the removal of links. You should still be able to find 15.04.06 and 2.3.1 as they are the most used/downloaded legacy versions. Have you tried these already?
Oh! yeah the link is broken. This might work:
https://www.imade3d.com/resources/Cura/Older Versions/Cura 2.6.2/
21 minutes ago, SandervG said:Hi @DrSchmoll, if I'm not mistaken we're in the process of removing some older legacy versions to keep things organized and structured. Unfortunately the removal of some versions seem to have gone a little bit faster than the removal of links. You should still be able to find 15.04.06 and 2.3.1 as they are the most used/downloaded legacy versions. Have you tried these already?
I haven't tried these but I will be sure too, however, if they don't work would there be any way of getting 2.6.2?
Thank you for the help!
9 minutes ago, gr5 said:Oh! yeah the link is broken. This might work:
I think this may work!
Thank you!
gr5 1,967
https://ultimaker.com/en/products/ultimaker-cura-software/list
