Follow up questions...
Does it matter which direction the aluminum block points?
From all the moving around, twisting around building it, that's sort of where the aluminum block has wound up. Do I need to twist is around to be positioned elsewhere?
LePaul 310
If I may suggest an edit to the Wiki...
Route the CPU fan wires first, once the other wires are in there, good luck getting that plug connector to fit thru!
