You will always have a z seem, but sometimes more sometimes less visible. But with your object, it is hard to hide the seam 🙂
@smartavionics Do you have more ideas, how he can get rid of his z-seam with this object?
Hi, I would use the user defined z-seam position option and specify x and y values that position the seam in the least visible position on the model. There are other settings that can have an effect on the z-seam visibility. The retraction settings, print outer wall first, coasting (not recommended), wipe outer wall, etc. You will need to play around and find the settings that work best with that printer and filament.
thanks, everyone!
Smithy 1,135
It could be the z seam. Try to set to set "Z Seam Alignment" to random, then it should be distributed all over your object.
waldo 3
I'm not sure that's an improvement 😉
bit I'll try!
Edited by waldoLink to post
