I started a print, but this sensor seems to be usefull for the starting position of the printer.
So I had to switch off the printer when it was forcing on the belt :(
I also tried to upgrade the firmware with the wizard, but no result.
May I try an other sotware ?
SandervG 1,521
Hi Martin,
I would advise to skip this test in the first run wizard.
Sometimes it is buggy and therefore give you wrong information.
Most likely your end stop is working just fine.
I would advice to start a print, and manually press the end stop to see if it interferes with the movement of your printhead.
Or you can just start a print and finish it, and share your results with us! :cool:
