Try a couple of these custom supports? They might work for your model. But don't expect miracles, it will allways be ugly. The ribs allow to make the gap smaller, without the support totally fusing with the model. If you provide enough methods for removing the support later (separate parts, holes for hooks and pliers, handles to wiggle things loose,...) you can also reduce the gaps. Making the support extend a bit (see bottom right in first pic) lets the model adhere better.
The bridge in the last two pictures uses a separate support-bridge, so the supports don't go all the way down and don't destroy the text. It also has ribs for smaller vertical gaps.
Maybe the same results can be achieved with standard supports in Cura nowadays. But I prefer to design my own custom supports, due to my often small or specialised models.
geert_2 560
