Posted · Unable to print - layer not sticking
Just built my machine but ever print I try has the same issue - I get a thread of plastic from the head but this does not stick to the plate and just curls up into a tangle.
Tried
- starting print with head just above plate (about the width of a sheet of paper)
- PLA 190 degrees
- PLA 250 degrees
All ends up the same, nothing sticks to the blue tape on the printing plate.
    I would suggest raising the build platform even just a little bit more. If you close the distance to the point where it has a hard time extruding and it's still is not sticking, I would check that you are actually using PLA and not ABS. ABS does not stick worth a darn to blue tape, and it will bruise when you bend it while PLA tends to snap.
    Also stick to about 240ish for now.
    It is PLA. I ordered ABS but was only sent PLA by mistake so that is all I have. Will try raising the bed further tomorrow when I make another attempt (and see if anyone else has any ideas).
    On the first layer, it should probably be smushing the plastic onto the platform - the distance between nozzle & platform should be less than the diameter of the nozzle hole.
    Also, make sure your platform is level..
    Follow this one. You might not need to oil the whole platform... a little messy in my opinion. I made a smaller sheet of aluminium foil, with some oil on the back to have it stick at the platform. Its enough to do it in every corner.
    As soon, as you Z is level and you have taped again. Start the print and grab the Z-Spindle at the lower end, right after the print starts. Turn it a few klicks until you see a little transparent film.
    Also, I configured netfab to print the bottom with low speed... helps a lot.
    I also printed a Z-adjuster from thingyverse... but this won't help you until something sticks :twisted:
    cheers,
    Micha
    as Dave said below, as long as you bed is level (nozzle-bed distance is the same in all 4 corners), you can adjust the first layer by manually turning the z-axis once the print has started.
    Not had a chance to try again yesterday, other things came up but will try the suggestions asap
    ok, progress
    I tried two things at the same time
    - removed the cooling fan from the print head (I think it was cooling down the plastic as it left the nozzle)
    - raise the bed slightly as the print starts (in fact I dig into the blue tape).
    Managed to now print something, hurrah, ok it;s only the square tube sample but it at least looks like a square tube so it's now printing something ..... hurrah
    It's job is to cool the plastic!!!
    I would definitely add that back on. It will become really important once you get going..
    It's difficult to get things just right.. Digging into the tape means the platform is too high.
    Have patience, try one small thing at a time and you'll get it right. Once you get it right, you'll spend a lot more time printing and less time messing with it..
    Blue tape tends to have a wax on it... try cleaning the tape with alchol or windex. I use windex and works great without the smell. In some cases it makes it so sticky I can't get the pieces off the bed with out pull up the tape.
    I'm pretty new here and to printing, but I have found 2 thicknesses of copy paper as a feeler gauge between the nozzle and the tape to work pretty well. That's about .008" or .16mm or .2mm
    Matt
          • Heart
        • 7 replies
