Hello @Zbyszko, you don't provide any details of your settings so I have to guess that it is underextrusion following a long travel. To cure that, set combing mode to no skin and the max distance without retract to 10. Hope this helps.
1
gr5 1,843
Well it's basic underextrusion on the higher layers. So what's different starting around 2mm above the bed? I don't know. Typically Cura cranks up the fan and also the speed slowly over several layers. It could be that you are printing too fast on the upper layers but cura is printing slower on the lower few layers (which is default).
What kind of printer do you have?
