Firmware 5.2.8 -> no camera
aag
Posted · Firmware 5.2.8 -> no camera
The title says it all. Since upgrade to 5.2.8, I have lost the camera stream (it's black). I reset the Cura Connect, to no avail. Any advice?
    Posted (edited) · Firmware 5.2.8 -> no camera
    I can’t speak to your issue however, I installed the latest firmware last night; the two step process with no apparent issues.
    Having shared this I have not initiated a print yet however, I just looked at the printer via the camera remotely via DDNS and it works fine and then accessed it via Cura 3.4.1 via the local network and it is visible.
    Takes care
    Edited by Shadowman
    Additional
    My camera is no longer working either. I updated firmware recently too, so I assume the firmware has an issue.
    I can also no longer calibrate x/y because it is printing it without any filament being extruded...
    Edited by akke
    Same problems here with my UM3. No camera and x/y calibration without filament being extruded.
    Waiting for the hotfix....but don't know if the camera issue will be addressed as well.
    Sarcastically with what I consider to be a level of truth embedded; don’t hold your breath as the concerns as conveyed by many versus the Ultimaker Team’s response don’t live in the same arena.
    The level of concerns shared that are not being addressed with any element of urgency as clearly evidenced by the actions, or better put; lack there of by the Ultimaker Team is truly dumbfounding.
    Takes care
    camera issue resolved with reinstalling UM app 🙂
    Personally, I do think Ultimaker Team is doing a great job.
    All confidence that firmware 5.2.8 is going to be superb after the first bug fixes are done.
    The world isn't perfect, but we can only learn from this and improve 🙂
    also happened to me.
        • 10 replies
