The only way I've found to change the color is to go to settings and configure cura. Create or duplicate a material and then on your new custom material, you'll be able to click the box that shows the color for the material, and pick a new color
- 6 months later...
Hello guys,
I am using Flashforge Creator 3 for dual extrution purposes, and in "Preview Menu", by using "Line Type" according to each material, I am able to spot different materials in each layer.
After updating Cura to 4.10 version, the option to change "Line Type" is gone.
As you can see in the picture below, where the drop down menu for changing the type of line once was, now there is this "compatibility mode" description.
Any idea how can I reappear the drop-down menu?
Longtoke 25
In the preview section, you'll note the bar at the top center of the screen that reads "Color Scheme : Material Color", click that and a sub window appears with a drop down box. Use the drop down box to select "Line Type".
That will color the sliced model based on the various actions during the print. You can also change the color coding once you're in that setting.
Enjoy !
Edited by Longtoke
ThreepE0 0
Did you try this yourself? I don't think you can change the color this way.
