Tomorrow you will find that you can fix this faster than you can locate and have the first sip of beer and you will wonder what all the sorrows were for, lol!
- 1 month later...
This happened to me yesterday on my UM3. I searched and I found this post, I am a quadriplegic so doing the repair described above is a little above my physical capabilities, I was going to get my wife to help me fix it.
I was so frustrated because I was needing to print. My wife wasn't going to be able to help me for awhile. I reasoned that if this was just a poor connection issue I may be able to give the white cable feeding into the printhead a little wiggle and a light pull. That is all I can manage anyway.
Well sure enough, it fixed the problem, I didn't need to bother my wife and I was happy on my way back to printing.
Thank goodness for this forum it has helped me out many times.
By the way, if anyone has some physical capability issues, I spend most of the time using my UM3 to create custom assistive devices to help myself or others to more successfully cope with our individual environments. 3D printing is tailor made for this role. I would love to communicate with others either in this situation or just people just trying to help.
I apologize for the hijack at the end.
Thanks for your post. I think it is very interesting what you do and design, so please share it with the community and open a new thread with more information. I guess a good discussion and ideas will follow.
Thank You for the reply, I am a bit new to opening new threads, but I will just jump in feet first (figuratively speaking)
Thanks again
gr5 1,971
I think it's a coincidence as this behavior has not been reported with the update.
So the cable comes loose quite easily. It takes all of 1 minute to fix it.
1) Remove the 2 long screws at the rear of the print head. You access them at the top. Removing those completely will not do much at all - things will still stay together.
2) Then remove the rear top cover - it covers the rear half of the print head and holds the cable in place.
3) Seat the cable better. Push down on both ends of the connector with some kind of tool or small finger.
4) Put some blue tape or scotch tape or other shim around the cable for better cable relief so the cable won't slide upwards and pull the connector out again a few months from now.
5) Put it back together
gr5 1,971
Here is a better guide with photos! And a video! But they don't suggest the shim. Do the shim step also! (step 4 above).
https://ultimakernasupport.zendesk.com/hc/en-us/articles/115004169003-Reseating-the-Printhead-Cable-Ultimaker-3-Series-
Ettuf 0
Thanks.
Since its the weekend i decided to drown my sorrows 😛
Ill try it tomorrow.
