I'm curious what temp you are printing at. Sometimes I get that with some brands of filament and have the temp too high
yellowshark 153
The other thing you can do to help is to lower your flow rate for the first level by 20-30%
burtoogle 516
It looks like the nozzle is too close to the build plate.
gr5 2,333
I agree with smartavionics. If you can manual level then that is best. Turn the leveling screws so the nozzle is about 0.1mm farther from the print bed than it was when you did this print in the photo.
