Aftermarket PrintCores for UM3
Posted · Aftermarket PrintCores for UM3
I have used the 3DSolex print cores since I first purchased my UM3 Ext machines with great success.  Highly recommended.👍
You'll get 0.25, 0.4, 0.6 and 0.8mm nozzles on an AA core.  They used to have an exchange program using your AA print core.  Can't say that is still the case though.
    If you are in USA, I sell UM3 and S5 print cores with swappable nozzles at thegr5store.com.  Otherwise if you are in the rest of the world try 3dsolex.com.
    Are the nozzles on the 3DSolex possibly the same thread size as the Olsen Block nozzles?  I'm probably going to buy a 3DSolex hardcore but hope to reuse the OB nozzles I already have.
    No they don't fit. The hardcore nozzles are longer.
    Uhm, the other way round 😉
    Thanks, I thought the hardcore ones are longer.
    So let's say they are of different length 🙂
    Thanks, Smithy.
