It could be that the teflon (PTFE) coupler has been deformed over time. This is the white part between the PEEK part and the bowden tube. The head is fairly easy to disassemble. Take out the white part and inspect it. Use a small screwdriver to (gently) feel if the channel is still straight or if it has a bulge or severe discoloration. It may need replacement, it is a $15 - $20 part.
- 1
geert_2 558
I don't know the UMO, but on an UM2 there is a little fan at the back of the nozzle, cooling the seam between nozzle, teflon coupler and bowden tube. Probably there is one on the UMO too? Did you check if this little fan is running at full speed? If not running at all, or if too slow, heat would indeed creep up into the filament, melt it above the nozzle, and make feeding and printing impossible. The fan could be worn-out, or it could have sucked-up strings or hairs from prints and gotten stuck, or a cable came off?
ahoeben 1,986
The UMO does not have this fan (the UMO+ does).
