I have now the new 2.1.4 Mainboard with the newest "normal" firmware installed. I did that with cura.
And I do not have unplugged in the jumper on the new Mainboard.
I can't change the step/mm at the moment as the Ultimaker likes first to go through all these first calibration steps. But I can't go though them, as he likes to lift up the building plat until it hits the head. So I have to switch it off.
What could you recommend?
I think with the installation of the firmware the parameters are retested and it's calibrations are set to not use the 8/16 jumper. Right?
tinkergnome 918
Well, as one of the first steps you have to provide any new mainboard with the correct firmware for your printer - preferable before you put it into the printer... But by now this is already done, if i understand your description right?
In addition: if you double the microstep setting you have to double the setting for steps/mm as well (from 200 to 400).
And please do not use aluminium foil.... 🙂
