You can try to change the setting "Outer before inner walls" but it is normally not checked, which means the inner wall (green) is printed first. But not sure how it behaves with the holes, so give it a try.
But anyway, your first layer should not come off, regardless of what is printed first. So you should check your nozzle distance to the bed, maybe it is too far away. Additionally, as MechDesiner already mentioned check your bed adhesion.
MechDesigner 3
What type of bed adhesion are you using?
I have the same problem with small holes, I create a thin material that fills the hole in and drill them out.
