Thanks for the response! I checked out the link but the installation instructions link leads to a dead end webpage. I'm going to look into this upgrade.
I also included more pictures below with the same hole type artifact. It can't be the nozzle since I just upgraded to the olsson block. This material is colorfabb xt printed at 245 degrees with a speed of 50mm (outside walls as per Cura 25mm). The white benchy above is the normal colorfabb PLA printed at 220 degrees (all the others are colorfabb xt). You can see that the white benchy over extruded on those same exact spots as the other benchy's where instead holes were created. I'm just not sure if this is a temp issue, start and stop point issue, or like a jerk acceleration type issue. Maybe all! lol. If you see the guys pant vs his cape...there is a notable difference in smoothness. Thanks for all the help!!!
gr5 1,971
Those diagonal stripes we call "zebra stripes". Google about it in this forum e.g. "site:ultimaker.com zebra". There's a nice video that explains what causes zebra stripes and a nice way to fix it posted by I think "triangle labs".
I sell a kit that takes care of this. Or you can get it on aliexpress:
https://thegr5store.com/store/index.php/tl-smoother-removes-zebra-stripes.html
The other issue I'm not so sure about. Hopefully someone else has an idea.
