>BTW, I created git repos in both of those directories
Brilliant!
I never create or store profiles. Instead I *always* save as a project ("file save"). That saves as a .3mf file. Then later when I print something new I think "let's see - this is similar to that part I printed yesterday" and I load the 3mf file for that part and then delete the old and drag in the new part.
burtoogle 514
Hello @changedsoul, on the Linux side, Cura stores state in ~/.local/share/cura/VERSION and ~/.config/cura/VERSION.
BTW, I created git repos in both of those directories which I occasionally use to snapshot my profiles, etc. Then if Cura goes berserk and trashes everything I can recover my previous state easily.
changedsoul 2
What would be the equivalent directories under windows? I notice there are a few places, AppData/Local and AppData/Roaming. Roaming seems to be the bulk of it, but I can not seem to get my print settings to carry over. I tried placing the the AppData/Local into the .config/cura with no luck. I also seem to have a cura folder under .cache, so I have three, one is .cache, .config, and .share.
