My nylon sticks so well that it sometimes pulls a chunk of glass off when I remove the part. For nylon I use the exact PVA mixture shown in this video but UM recommends to use glue stick alone to prevent damaging the glass (nylon and CPE have each damaged my glass they stick so damn well).
Anyway watch this video to understand techniques to keep parts on the glass - you should be able to pick up the entire printer with a small UM robot print (I do this in the video).
gr5 1,843
I sell them: thegr5store.com
Get a 35W while you are at it. The nozzle heats up faster and doesn't limit your printing volume as much: if you print with 0.8mm nozzle and at 0.4mm layers, the standard heater can't keep up (just printed a 1mm nozzle 0.5mm layer part yesterday).
