I'm using an Ender 3, and the filament is a new national filament (which is supposed to be printed with the same settings as PLA, because it's not a filament that much flexible). I will try oiling it, the settings I'm currently using are:
- temp: 220C
- speed: 50mm/s
- flow: 110%
- retraction enabled, 5mm @ 25mm/s
I know that these settings aren't for most flexible filaments, but as I'm telling you this is a "new" "experimental" filament type. Supposed to be just as easy to print as PLA (and so far, aside that inconvenience, the prints are flawless, I attach a side/bottom view of the print)
I'm currently printing another with these new settings (and I included the oiler):
- temp: 220C
- speed: 40mm/s
- flow: 115%
- retraction enabled, 6mm @ 25mm/s
I'll let you know what happens.
Edited by fjallbacka
gr5 2,334
The problem is underextrusion.
What kind of printer did you use?
If it's a bowden printer like an Ultimaker you need to oil the filament. Put a drop of oil on the filament before inserting it. The oil will not affect the print in any way. Really. Add another drop every meter or so.
You many need to slow the print further. Maybe down to 10mm/sec.
These 2 things - oil and speed are probably enough.
You may need to increase the temp as high as 240C. It depends on which filament you are using exactly.
