Sadly reassuring... I had wondered bout the timing of the failures.
Thanks anyway.
Thanks anyway.
I heard it's working in 4.0 and I heard a rumor it is fixed in 4.2 (which isn't out as of today). I don't use support very often so I hadn't noticed. Also I'm still on 4.0.
Is it worth going back to 4.0 or is 4.2 imminent?
EDIT - it does indeed work in 4.0...
Edited by WulfCI would guesstimate that Cura 4.2 will be released around one and a half month from now, barring any unforeseen blocking issues.
Thanks, I'll just stick with 4.0 until then.
Hello @WulfC, if you are running Cura on either Linux or Windows then you could use one of my builds which are based on the Ultimaker master branches + my own work. You can find them at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
I don't know if the fix you require is in place yet but if Ultimaker have fixed the problem then my next build should be OK.
Thanks, but I have discovered I can have both 4.0 and 4.1 on my PC at the same time - if I click on a file to open it it'll always open in 4.1, but if I need 4.0 I can open that first. That'll do nicely until 4.2 appears.
ahoeben 1,654
“Print as Support” seems to be broken in Cura 4.1. Not your fault (for once 🙂 )
