It's not a Cura 4.1 bug. I get the same result with Cura 3.6 at the sale layer.
M104 S235.000000 T0
I Can't figure out what's going on ???
M104 S235.000000 T0
Instead of posting the gcode file, could you post the 3mf file? In cura do "file" "save" and it will save everything - your printer settings, your profile settings, your model, where you positioned the model, everything.
Err, no, try again, we want to see the .3mf file. Do File -> Save from within Cura so that it will save the model and the settings into a Cura project file.
Sorry ! tough day !!!AU30_Button v4.3mf
OK, thanks for the project file. I sliced that and the only temperature setting commands set 220 at the start of the print and 0 at the end. There's no change-at-z script as far as I can see. Dunno, looks fine to me.
Burtoogle, Thank you !!!!!!
I've found the bug !
There was actually a postprocessing code that changed the temp.
Peter
Good, glad you have sorted it out. Cheers!
burtoogle 506
It's probably been affected by the change-at-z script that has been diddling with your gcode...
;LAYER:32 G1 F2700 E528.58937 ;MESH:Object 1 G0 F7200 X110.319 Y109.188 Z5 ;ChangeAtZ V5.1.1: executed at 5.00 mm M117 Printing... ch@ 5.0 M104 S235.000000 T0
