Well, I am still confused. The steps I take are these.
1, open Cura 4.1
2. Open my Open my .stl File. I have made sure I have only 1 object on the Cura display. I have renamed this .stl object. Is this a problem?
3. I preform the slice. I produce an output, but the Filename still has the .gz extension.
4. I have created a ‘Gcode’.group on my laptop as well as the micro-sad file that receives the Cura Output.
I seem to be missing a step or a Needed Cura modification. I certainly appreciate your time helping me with this problem.
‘By the way, my next endeavor is to Make my Ender-3 recognizable by my WIFI. Oh, boy.
ahoeben 1,657
The .gz file is a compressed (zipped) gcode file that your printer does not support.
If you slice a file and then go to the file menu and select the “save as” option, you should be able to select gcode instead of compressed gcode. I think if you do that once, Cura should remember your choice.
