Yes the file is there. If it was the file I installed and uninstalled different version and all fail so far.
Do you happen to have a firewall or a virus scanner running? They might block cura from accessing the file. Alternatively, you could also try to run Cura with admin rights.
I have Cura running in admin, I don't have a firewall or virus scanner running turned them off to tried it still nothing
I was able to fix it I had change a few settings for my ram in the register editor and i'm guessing it was not giving the CuraEngine.exe enough to fully run that would be my guess. Thank you for the help tho
Could you share what settings you had to change?
I found that turning off the paged memory was stopping the slicing process.
1
- 6 months later...
hi there
just wanted to say that i have tried a lot to get cure to slice and nothing has worked up till now:) i tried the paged memory thing and different cura versions with no success but then i had a brain fart :) i thought .... its struggling with something:/ anyways all i did was changed my support "support pattern" to triangle and hit slice and the twat worked 🤔so hope this helps someone
nallath 1,080
Well, the logs state that it can't find the backend at " E:\Program Files\Ultimaker Cura 4.1\CuraEngine.exe"
Could you check if the file is there?
