5 hours ago, neotko said:Your first layer is too close to the bed (clearly visible on how that brims shows transparency). That makes the filament buildup and it fixes as soon there’s room for the excess to crawl (non solid layers).
make a first proper layer and it should fix itself
I've printed at multiple heights from the bed attempting to solve the problem. All have the same results. This one wasn't actually too close either. It was set with the .2 mm feeler gauge and the first layer was perfect other than a tiny blob where the layer started. What looks like a thin line on the skirt is actually a bit of left over clear filament mixing with the black.
neotko 1,418
