Ok lets see what i can answer :
Print speed : 149mm/s
Temp 205 :
Filament is free flowing and not tangled (as much as it tries to be lol)
I have noticed alot of heat transfer to the metal plate that the hot end passes through , when i was clearing the head at 250 it was enough to soften the PLA fan shroud
Having just turned the printer on to remove the PLA all i got was puffs of smoke out of the hot end , which is what happened last time (i posted about it and was told it was most likely a plug) , have to push the filament through by hand till i feel it give , and then it flows again , not sure if the nozzle is blocked again and that causing the PLA to back up and plug ?
gr5 2,071
1) Could be dust. Are you in a dusty environment? Some people use some tissue and tape to make a loop around the filament as it is about to feed through the feeder.
2) Are you sure it's a clog? Measure the new PLA with calipers. If it is > 2.99mm then it probably occasionally hits 3.05 or 3.1mm which is enough to get stuck in the bowden tube. You could verify this on the next "clog" by trying to pull the pla out and it should be difficult.
3) Could it be wood splinters from the feeder? Open up the feeder and look in there carefully with a flashlight at the hobbed bolt. Maybe even remove the black delrin clip and slide the big gear out and look at the area carefully.
4) Could it be your filament is tangling? This often causes problems after a while.
5) Could you be printing too slowly? If you are printing .2mm layers I doubt it but if .1mm you should be printing at least 50mm/sec if not 100. And if .05mm layers than at least 100mm/sec. I mean many people can print slower but if you do heat can drift up the hot end. Especially if there is lots of retraction (which slides the heat up due to sliding warmer filament). Then what happens is the filament gets too soft high up in the hot end assembly. Actually this probably isn't the problem as you would have noticed clogs high up (as opposed to at the nozzle).
What do you mean exactly a "plug"? Is it the kind in #5 or is it down in the nozzle?
If #5 then print cooler/faster and with less retraction (4.5mm is plenty).
