You were right!
The fabric conduit around the outside had frayed down a bit and the two wires were contacting down near the plastic so it wasn't easy to see.
Thanks for the help and hopefully it will keep working well! I may have tidy up the wires a bit to stop it happening again.
gr5 1,967
You may have damaged your electronics inside the print head.
You wired it up properly otherwise it either would not heat up or it would not read back a temperature.
What you did wrong is you created a short somehow. There are 5 contacts - there are 4+3+2+1 or 10 possible shorts. Check every combination. The left two pads should be the heater so around 25 ohms. The right two pads should be the sensor so around 109 ohms at room temperature. ALL other combinations should show as an open (certainly > 200 ohms). The short would have to be less than 5 ohms to cause the heater to not stop heating up.
MOST likely location for the short is between where the right hand heater wire is right next to the left hand sensor wire. There's probably a tiny tiny strand of wire bridging the gap there.
