The bottom layer. The first layer. It's very critical. The default settings set the bottom layer to .3mm so your levelling can be off by a whole .1mm and you will be okay.
But if you start printing the first layer at .2mm now you need levelling to about .05mm accuracy and if .1mm then you need accuracy to about .03mm.
So the first thing you need to get perfect is levelling. You know you have it perfect when the bottom layer looks like this photo:
http://ultimaker.ipbhost.com/uploads/gallery/album_203/gallery_4795_203_296761.jpg
The other thing - is if you clean your blue tape with isopropyl alcohol - this will make things stick to the tape much better. The blue tape has something that is not sticky on it when new. You need to clean this off with isopropyl alcohol (or other solvents will work - probably paint thinner will work but then you have to wait for it to dry - acetone will probably also work).
If these two advice don't help, please show photo of part that didn't stick if possible. Especially photograph while printing the first layer.
IRobertI 521
Could you be more specific with what you're having trouble with? A "bad" print is a very wide term
You say that you are having trouble especially on the first layer, what is failing for you? Is it not sticking properly or is there some other issue?
