People have found that the wired network is more reliable on the UM3/S5 so if you can do a wired network that may save you a lot of headache.
In my experience, a wired network doesn't help much in this case. My UM3 and S5 are wired and I still have to do a Cura Connect reset on both of them from time to time for the camera to work again.
I do have a wired network. So you're saying this reset is something I do from the printer directly and not the web browser right?
Yes you find it in the menu on the printer and it is called "Cura Connect Reset"
I am not at my printer at the moment, so I cannot check where you find it exactly, but it is in the same place as factory reset, infos and so on.
Just wanted to come back and say @Smithy that the Cura Connect Reset did work. Thanks for your advice.
Thanks for the update and I am happy that it worked for you.
You will see from time to time it can happen again that everything is working except the video stream. Then just do a Cura Connect reset again.
- 2 weeks later...
Well; experiencing camera offline now too. Resetting Cura Connect did not work; any other suggestions.
Thank you
I have the exact problem from time to time with 1 S5 and 2 UM3E.
Doing a Cura Connect Reset on both the S5 (hosting the Cura Connect Server) and the faulty UM3E does the trick at the moment.
Thank you.
I will do a full reset of the network and another Cura Connect reset and see how this does.
Takes care
Smithy 1,145
You can solve this issue by doing a Cura Connect Reset on the printer, this "repairs" the non working video stream.
But, you are using a group host and the drawback of a Cura Connect Reset is, that you have to create your group and members again.
