1 minute ago, SandervG said:Hi @jbearpark,
perhaps you could also give these settings a try with PLA:
Line width: 0.4
Wall thickness: 1.2
Top/Bottom thickness: 1.2
Speeds: 40
Jerks: 20
Horizontal expansion: -0.03
walls: 3
Where one print was smaller or taller than the other, are these from the same gcode / same model?
Hi @SandervG
Thanks I'll give those print settings a try.
The two models were different. Essentially one was a 15mm radius dome and the other was a 20mm radius dome (hemispheres + 15mm cylinders at the base). I just remeasured them and realised they are both actually too tall but one is +1mm while the other is +2.8mm so there is still a considerable difference between the two.
SandervG 1,505
Hi @jbearpark,
Line width: 0.4
Wall thickness: 1.2
Speeds: 40
Jerks: 20
walls: 3
