Actually, I think what is happening is that the wall overlap compensation is enabled and because the wall is thin, the resulting 2nd wall contains very little filament. To stop the pointless travel set the minimum wall flow value to something like 50 (or even higher) and it should stop that pointless travel occuring.
- 1
gr5 2,207
It's caused by a feature called "combing". You want combing off for this part. It's combing the long way around. The combing feature used to be a bit smarter about going the shorter way around. In fact I thought this bug was only in cura 3.X. Not Cura 4.X.
