Thanks for explaining a bit of the history. I’m sure there are all sorts of things going on that I’m not seeing. The irony of this is that I am using a fleet of Ultimakers to design and prototype a device running embedded Linux, which has lots more going on than meets the eye...
Yes, the convenience aspect makes sense, especially if you are dealing with a large IT department and just want to get up and running quickly. However, long term, having IT bought in and proving some services could actually lessen the load on those operating the printers, especially if you have any significant number of them installed. It cuts both ways, in my experience. And I don’t think there is an exclusive answer. This one is firmly “(D) All of the above” in my mind.
So how much work do you think would it take? A month? A year...? Is there a list of required packages somewhere? I don’t mind a little work if it keeps me from losing progress / connectivity on the whole set of printers every time the first one gets rebooted or crashes out... is it just some python code and external dependencies...?
nallath 1,067
Requested & cotemplated before? Yup. Actually possible? Nope.Theoretically you are right. I should be possible to do this, but as you might have guessed there is a bit more going on than meets the eye.
The main reason we hosted it on the printer is convenience; No extra hardware is required to set up the clustering. This is especially a thing within companies where you usually need the involvement (and thus approval) of the IT department for any and all new infrastructure.
Currently Cura Connect has a bunch of assumptions regarding what operating system (and with what other services) it's running. So should be possible to get it to run, but it will require a fair bit of work to actually do it.
