If you clean the tape with isopropyl alcohol it will be even sticker. So DON'T CLEAN THE TAPE. Use fresh tape and it won't be so sticky. By the second print it will be stickier so I would change the tape after every print.
Also you can increase the skin thickness in Cura to make the edge of the cylinder stronger. Go at least 1.2mm (4 passes of .4mm nozzle).
Lift the edge with a knife carefully. Be patient. Then when you get a little space, use a putty knife.
anthonyt 0
I still use the blue tape, but when the parts stick too much, you could try using this tool:
Print Removal Tool - Stanley Blade Adapter
http://www.thingiverse.com/thing:138821
Beware that it can be quite sharp.
